Bought an upper radiator hose 12 yrs ago
Results 1 to 3 of 3
Thread: Bought an upper radiator hose 12 yrs ago
  1. #1
    Newb
    Join Date
    Sep 2019
    Posts
    2
    Post Thanks / Like
    '68 Dodge Dart 440. Will post a picture. JIC I need a new one. Didn't save the p/n
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Full Member my64dart's Avatar
    Join Date
    Dec 2005
    Posts
    497
    Post Thanks / Like
    Hi,
    Check out Rock Auto. They have a few molded hoses for a 1968 Dart with a big block. You can get the part numbers and then order it locally if you want to. If it doesn't fit you can just return it for a refund.
    383 stroked to 432c.i. / 440Source Stroker / Edelbrock RPM heads / 750 Holley / Torker Intake / Lunati VooDoo cam / Dynamic 9.5 converter / Cope Racing Trans / 3:55's with a suregrip /I'm Always Working On Something
  4. #3
    Full Member 1968rt's Avatar
    Join Date
    Jul 2007
    Posts
    135
    Post Thanks / Like
    radiator hose
    If the top hose is on the passenger side, Gates 20630 should work. Might need a slight trim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
