Msd distributor
Results 1 to 2 of 2
Thread: Msd distributor
  1. #1
    Full Member brandon6973's Avatar
    Join Date
    Nov 2010
    Location
    old hickory Tennessee
    Posts
    497
    Post Thanks / Like
    Msd distributor
    Looking for an msd distributor for a B block.
    I just want the front wheels to come up off the ground when I take off, is that too much to ask?
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Full Member Demonracer's Avatar
    Join Date
    Nov 2010
    Location
    Cleveland, TX
    Posts
    152
    Post Thanks / Like
    Here is a suggestion for you, look for an RB distributor & get the spacer collar to run an RB distributor in a B motor. I think the RB distributors are probably more readily available. That's what I did when I decided to upgrade my ignition system a while back.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
