you will have to check for yourself. i had a set of 11x2" brakes, the drums were bad and they are almost imposible to find new 11x2" drums. i tried one of my drums from my 11x2.5" setup, it fit fine, those drums actually had 3" of contact surface, it all depends where the shoe rides. if the shoe contacts the drum all the way inside the drum, it should be fine, if it contacts near the edge of the drum, i dont think i would use it. measure from the axle flange face to the edge of the shoe, see how far the axle sticks out past the shoes, then measure the axle contact flange on the drum and see where the shoe will contact. how much does your axle stickout from the backing plate where they attach to the housing? i actually had 2 sets of the 11x2" drums, one from a mid 70's valiant the other from a 66 polara. they both used the same axle offset as the 2.5" brakes.
