1 - 5 of 5 Posts
I had a question, these larger tie rod ends, will they bolt up to my steering linkage, i can't think of the part name but it's the sterring bar that hooks both sides of the wheels together.
70 Dustpan said:
Yep, the stud size is the same so the will bolt up to your center link / drag link. It's just the threaded size that is larger.
center link! thanks lol ok just needed to double check on that, i'm hunting all the parts down and so far so good! the tie rod ends and adj sleeves are alla day out from me
Measure the length of the C body sleeves. I got a set off of a early 70's C body and the are to long. (8 5/8" I think) I ended up have a set made up out of alum. hex stock at 7 1/4" long.
Discussion Starter · #5 ·
Steve Strope over @ Pure Vison makesthem as well teh Hex stock, i di dnto factor in the length.
Thanks!
1 - 5 of 5 Posts
