I'm switching the Valiant (68) to disc brakes on the front and am rebuilding the front end and have upper control arms from a 73 disc brake car. I'm wondering if I need to get the offset upper control arm bushings or do I need to try to align it with regular ones?
Second question (may be dumb) brrrrrt - In the tech section it says the regular 68 (drum) lower control arms will work and use 73-76 lower ball joints. Is it just the ball joint socket that's bigger and not the stud? If the studs bigger its not going to fit in the control arm. Could someone clear this up???
