1 - 5 of 5 Posts
My 440 source deep sump pan is hitting center link on right turn. Seen alot of different suggestions from Big hammer to welding in piece. Since I will also have a girdle on it it will also be more of problem. Decided to have it cut for cleareance and weld in new piece. Hopefully this will take care of problem.
.............I have that pan on my stroker that will be going in in about 2 weeks, hope it fits............kim.......
Every Abody BB car I have seen with an aftermarket pan hits I think I'm going to weld in a notch on mine
welding
Yes I had the same issue with 440 Source oil pan and cut it and welded.I also welded tabs in the pan to mount the windage tray without sandwiching it since I also run a girdle.
1 - 5 of 5 Posts
