1 - 7 of 7 Posts
i have a good 331 hemi and 66 dart has anyone ever put hemi in a dart or can it be done if so what needs to be changed thanks
"Wanderer" at Gentry's Garage was doing that some while ago. He's more often found on the Early Valiant/Barracuda list these days, I think.
You probably already know this but some 331's have part of the bell housing cast on the block. That makes them very difficult to adapt to a modern transmission. So make sure you have the later 331 that uses a more conventional bell housing setup.
there is a guy in ohio,,adapting GM, bell housing,,for a 4 sped set up to the early 331 with bell attached,,
also some street rodders are now milling off the cast bell and using an adapter plate to mount a 727 or 904 A..
1 - 7 of 7 Posts
