1 - 11 of 11 Posts
I just got home with my new project (a '72 Dart "roller"). It's been completely stripped (including all glass and trim) down to the bare shell, minitubbed and primered inside. I want to install an 8-point roll cage and wonder if there is an existing kit I can buy?
Also, am I correct in assuming that the cage should go in before anything else is reinstalled or painted? Body color for the cage would be fine..
thanks
Charles
Thanks! that's just what I was looking for. Auto Weld does have a listing for '72 Dart... they call it a roll bar thru 8 pt. and a roll cage for 10 pt. and up.
Now the question is, for only a little more I can get the 10 pt.
Is it worth the extra weight and cost?
-Charles
I'm happy with my Competition Engineering 8-pt that I put in my demon, would be the same as for yours...Check out my site for a few pics...
Ryan
If the car is going to have sub frame connectors it would be better to install them before the cage. The main hoop can then be attached to outriggers from the frame connectors.
While it requires more fitting and fabrication, I think that the "A" bars on a roll cage that go through the dash are worth the effort.
mike.
I put a 8 pt kit in my 71 dart from comp. eng.(sold the car) doh
I have a 12 pt+ cage in my cuda from autoweld
they both were 1 5/8 tube .125 wall. both kits are good
but the autoweld had a better fit and had a lot of the ends
pre notched, like the sholder bar that runs behind the seats
between the loop bar, it just droped in place...real nice.
One of the ends for the long bars going to the trunk is notched with
the autoweld kit also. I dont remember any of the comp bars being pre notched.
My fabricator (my best friend owns a fab shop ;D) liked the autoweld kit better too.
one other note you can buy the kit cheeper than you can buy the
tubing and bend your own so unless you want a true custom bars
go with a kit.
1 - 11 of 11 Posts
