1 - 4 of 4 Posts
first off i find this is the most helpfull site on the net, thanks . i 'm going to make a kit insted of buying one but i need to know the i.d of the pipe you guys are using throughthe rear frame rail ?.on the shackle is there a rubber bushing only that would go through the pipe? next on my list ismoving the front eye hole back an inch for some tire clearence. is there anything to be aware of like drive shaft length? pinion angle i'll check . thanks for you help -0*(
Get a pipe with an ID the same as the OD of the bushing. I found some galvanized pipe around my house that fit perfectly. The bushing is the only thing that goes in the pipe. with the shackle of course.
Remember if you move the front back 1", the rear shackle hole will need moved. Also If you plan on running Super stock springs, the right side spring does not get moved as far as the driver side. Due to the arch of the spings.
1 - 4 of 4 Posts
