Hey Everbody, does any body know what the weight for the alterktion compared to the factory setup would be? Is the alterktion kit lighter? For 70 Dart.......Thanks Matt
You are correct, sir. After I installed mine on my duster, I weighed all the parts. It came up to be roughly around 90-95 pounds of weight reduction. If you have power steering and are converting to the manual rack, you would more than likely save more weight...as you would not be using the power steering pump and the power steering gearbox is heavier than the manual (aluminum) gear box.abodyjoe said:i think it is suposed to be like 80-90 pounds lighter the a stock set up... i plan on weighing my car before and after i install mine..
[]{}Tubbed440 said:If all you're going for is weight reduction, then the price you are going to pay is not worth it.
[]{}HB69DART said:For me the reasons for buying are improved handling, safety (better brakes), cool factor and weight savings.
