I have read several discussions on here about the linkage rubbing the oil pan I want to see if this is where other people had the problem. I just pulled the motor out of my Big Block 65' dart and you can see where its pounded out on the pan I have and where it's hitting the linkage. I just wanted to see if anyone can tell me if this is where their linkage was rubbing and what oil pan may work? Or at least an oil pan with a shallower tail end on it that might require less pounding out. Or a pan to start with to have someone notch it out and fabricate one
