1 - 7 of 7 Posts
I put in poly graphite lower control arm bushings. After getting the front end together. I went to snug up the nuts on the lower control arm stud and the stud just turns when I try to tighten the nut. Any ideas on getting these to snug up? Dave
that's been the big question on lower bushing in poly,is that they freely move. i'll took a vice grip and held the pivot at the base and tighten it.
That was a problem on my RR also. Shops like Mancini and PST say don't use poly LCA bushings. Mancini has O.E. Moog for $13 each. Got some for the Dart.
Tom
Discussion Starter · #6 ·
Well, I went and bought soom moog LCA bushings. The ones from Energy susp. cam apart without the press( way loose). Pressed the Moog parts in and that was the last off my problems. ;D Dave
1 - 7 of 7 Posts
