1 - 20 of 27 Posts
im looking at doing my upper ball joints this weekend i have been searching this site and found out alot of info, how ever every thing i read on it people seem to just use the socket and impact or alot of leverage, now in my FSM it says i need chysler tool c-3711 to apply pressre and hit with a hammer to losen the stud??? it looks like a bolt on top of a stud with a longer nut on the bottom, is this nessary or can i get away with just the socket?
Premium Member
You need the socket, but before you unscrew the ball joint you need to separate the ball joint and spindle. I have had good results from just hitting the top of the spindle with a 3lb hammer AFTER the nut is removed.
Removing the ball joint from the knuckle is the easy part, the ball joint screws into the upper control arm
and it will be very tight, you will need the factory style ball joint scoket for this . Depending on the year the lower ball joint will bolt in (easy) or press in, you will need a ball joint press for this .I hope this helps.
Discussion Starter · #6 ·
yeah, the uppers seam easy i was just thinking about doing the lowers once i was in there goofin around, my fsm says i need the press, when i talked to the "parts specialist" at the bumper to bumper they said it was like a hole assembly not just the ball joint, thanks for the help now i just hope i dont break nothing o[ o[ o[
I'm pretty sure the stock lower joints are screw in too.. Were are you located?
Discussion Starter · #12 ·
so im about ready to hit something o[ o[ o[ o[ o[ i called napa and the told me that he cant get anything that goes back that far?! he asked if i wanted a 4wd hub wrench for a dana 44!! i called orielys and i guess they never made a socket and the checker said if i can get a size he might be able to help me so what is the size for the 73 and later upper ??
just suspension sells the socket....
my local napa has a machine shop downstairs and that guy has both sockets so i just get him to intstall the ball joints for me...
Discussion Starter · #15 ·
yeah i need this socket for this weekend im at school and i only get to work on my car durring the weekend and i have to go to the drags the weekend after this, what i have found is that it might be 1- 15/16 is that right??
abodyjoe said:
I won't complain as much about where I have to work on my cars.
  lol....   man it sucks being in the stones...  been raining the last couple days...  was decent thismorning so i started putting the drivers side together and then the down pour started and hasn't stopped....
been there done that and yeah still doing it! lol
Discussion Starter · #18 ·
its ok, ive heard that from some one else too maybe i will have to look in to that, i am about ready to choke some parts people! no one can even get them i think they are just getting sick of looking for things and filling me full of bs o[ o[ o[ o[ o[ o[ o[ o[ o[
1 - 20 of 27 Posts
