I am relocating the battery to the trunk and wondered about what type of shut off switch? I am using an alternator and would like to know if anything has to be done special. Let me hear the ideas
Not really, the cheapo switches are reated for 20 amps, the starter draws much more than that. A cheap swtch is usually the culprit for some voltage drop between the battery and the starter. Do yourself a favor and get a good Flaming River switch, they are rated at 200 amps.Brad4406 said:I went with the Summit switch just because it was a lot cheaper than the brand name ones. A switch is a switch, why pay more.
Brad
Here's mine. It's mounted inside the trunk with a push/pull lever.400dartguy said:Hey not to swipe the post- but where did you street driven guys mount the switch- Im about to do the battery when I do minitubs and spring relocation. I thought through the bumper, but what happens when you have a parking lot oops? Maybe extra wire and put it on the decklid?? tnku tnku BBD
