C
Craig
·Guest
HOW DO YOU FIX THIS BODY LINE?
Teeto said:I also don't wanna sound like a jerk to you either but calling a aftermarket "skin" straight is a stretch. I gaurentee you could straighten that panel in much less time than you could removing and replacing. Its not that bad of a repair at all. Second of all your going to have to section a new panel in down the entire side of the quarter panel. You can't go to the c-pillar as they don't even make a panel that goes up there. So in the end your risking tons of metal warping, welding, and grinding, and then filling the entire seam with filler down the entire side of the quarter panel. Risking all of the body filler prolbems you listed, that in the last ten years of doing bodwork I have never seen. Why would bodyfiller show cracks and shrink? Unless you are doing it wrong bodyfiller will last for a very long time. I think in the end you would be much happier with a repair than with a replacement. Just my .02 cents.
[/quote
I agree this is not that bad of a repair it could be straightened and when done have a skim coat of filler in it you just need to have someone who knows how to work metal to do it. their is no way i would put on a quarter skin to fix that you would end up with more problems than you already have.
