B
BlackGTS
·Guest
I can't get the brake lights to work.The bulbs are new and there is power to the back.
The brake light switch had a bright green wire on the end that moves and there was no power to it so I am assuming it is a ground.I attached a wire with constant power to the other prong but still no brake lights.When the pedal is pushed down allowing the plastic piece to move and the bright green wire touches the bracket the both wire have power.
The switch looks simple enough but I am not sure how it works.
Any suggestions?
Thanks,Dave
Any suggestions?
Thanks,Dave
