1 - 10 of 10 Posts
Will the backing plates and all that other stuff from the 7.??? rearend fit on the 8.75??? We have the 8.75 rearend to go under the 68...and was just wanting to know if the parts interchange..
Thanks
Rick
Thanks
Rick
I don't believe the backing plates from the 7.25 willl fit the 8 3/4. However, if you go to the nearest junkyard and find brake parts off a 8.25 or even parts off a 8.75 truck, they will work.
The backing plates have a different bolt pattern and won't interchange, but I used my shoes and drums from the 7 1/4 on the 8 3/4. This is assuming both rears are A body small bolt pattern. B body 8 3/4's have a different offset on the backing plates.
Discussion Starter · #4 ·
The 8.75 is suppose to be from an A-body car...I do know what the length is correct..How do I tell if its an A-body or ?????
Rick
As long as it is 51'' from end to end, and the spring perches should be about 47" from end to end, it is an A-Body.
Are you sticking with small bolt pattern? I am trying to sell some axles!
Discussion Starter · #6 ·
That is the plan right now is to stick with the small bolt pattern. We have a set of steel wheels and dog dish caps that may go on it. The back wheels will be widened with the correct offset once the mini tubs/springs are done.
Rick
Discussion Starter · #8 ·
Didnt know the center housing had to be narrowed to mini tub it??? The backing plates off of a 8.75 truck ...wouldnt they be for the 5 lug setup. What truck or car used the 8.75 small bolt pattern???
Thanks
Rick and Rickey Jr.
the truck brakes should be what you need .... I beilive they didn't change the bolt pattern on the truck till 85 or 86 so any 8 3/4 from a truck should have the right brakes ... make sure you get the E -brake spreader bar and lever when you get the plates and drums
o----o<>
You can't use any other brake backing plates if you plan to stay with the A body 4 inch bolt pattern. Stock A body axles have a different offset and require the A body backing plates.
1 - 10 of 10 Posts
