1 - 3 of 3 Posts
I have 1973 disks and calipers up front. The right caliper is brand new. All new drum brakes in back. Left side Caliper and Master cyclinder are 1973 OEM. Proportioning/metering valve is new and correct for the disk/drum combo. The system was bled correctly.
Anyhow, for quite a while, all was OK...then yesterday, the brake pedal goes all the way t the floorboard with No resistance. I might as well be pushing on marshmallows. I re-bled the entire system, starting from the right-side drum... no bubbles, no brake fluid leaks anywhere.
I'm thinking of replacing the Master Cylinder and the left side Caliper simply for lack of a better idea..
AutoZone has them for $23.00 and $32.00 respectively. Who says that Mopar parts are expensve...
Anyhow, is there sometyhing else that I could be missing..?
BTW, these are not power brakes. Plain ol' mechanical.
Premium Member
Sounds like it is simply the master cylinder. Sometimes when the seals go the fluid just goes past them. SInce there's less resistance with a bleeder open it will still move fluid.
jump in on your topic here but, when i swapped out ot the SSBC kit i bled the brake system about 4 times and i feel i coudl stop better and felt it better with my drum brakes.
and i did bleed the master cylinder i installed the car hooked it up to the pedal and ran the bleeding system and bleed it like that.
and they are manual disc brakes, am i supposed to use a diffrent metering block? and i do have the prop valve installed and also i don't have enough clamping force up front so my stand stills are a bit tough. any suggestions ideas?!
1 - 3 of 3 Posts
