So after much crawiling around and in my dart I have found 1 problem so far. There is some kind of voltage drop in between my alternator and battery, it goes from some where aroud 14 at the alternator to like 12.5 at the battery. The battery is mounted in the trunk with a master kill switch, but that wouldn't drop the voltage that much now would it? Now would that drop in voltage cause over time my battery to die? Cuz at the moment the car will run, just barely, most times I have to use the charger to get it running, but it will run and idle but my turn signals won't blink and the last time I drove it my radio would shut off every time I hit the brakes. So could that drop of voltage be my problem, or could it still be a short?
