161 - 173 of 173 Posts
Re: check out my new RMS rear suspension ..(pics)
Technically, it warps the housing. If you talk to an axle builder, they'll tell you that all brackets should be welded before the housing ends are attached because the tubes warp.
I don't worry about it though. This rear was slightly warped when I got it in original form, and this is the second time I welded the 4 seats on bottom and the tabs on top. This is the same axle that you see in the inboard leaf spring tech page, so it's been welded on all over the place a number of times. It's still only warped about the same as it was when I got it, and I never had any troubles with it.
And if you're going to use the original spring seats, the only welding required is the upper link tabs - the second set of seats does not have to be welded. I weld those top tabs on assembled rears all the time without a problem. This rear just had brackets all over the place, so I decided to clean it all right off and start from scratch.
Yea, I don't want to mess with the rod end links. I fear once it's together, I won't have much interest in looking under it, so I figured it'd be best to use the bushing links so I can just forget about it. The rod ends should be checked once in a while to make sure the jam nuts don't loosen.
By the end of the day here, the last thing I want to do is look at more suspension...
Discussion Starter · #165 ·
guess i better check mine huh.. i never did after it was on the alignment rack.. ooops.lol
Well, if they're tight, it's doubtful they'll come loose, but it's one of those paranoia things. If it DOES come loose, it can unscrew, so it's good to check :)
wow, that looks familier ;D
nice work, Bill...it's always the cobblers' kids that go shoeless. glad you carved-out some time to get yours done...you'll be amazed ;D
