1 - 8 of 8 Posts
Hey Guys,
Heard a rumor that a Booster and Master Cylinder from a Chevy S10 makes a great setup when the Engine Compartment space is tight. Has anyone heard of, or seen this application in a 68'.
Thanks....
Pat
o----o<>
Premium Member
I haven't seen it, but any booster that bolts directly to the firewall (I don't know if this one does or not) with probably not clear the rocker cover on that side even if using a small block. The factory booster is on a bracket that raises it up out of the way. I can get pics if you haven't seen one. That said, there really is no need for power brakes in an a-body.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Thanks... Just a stupid question, I'm dropping a 440 in her, with 11" Discs (73 Scamp) on the front, and 11" Disc (95 Explorer) on the back. Will non-power brakes have enough clamping force to bring her to a stop?
Thanks Man, you guys are the best!
Pat
Pat
I'm running manual disc/drum, it stops fine. Much better than four wheel drums.
95 explorer rear, please elaborate?? stock width??
thanks, Dreamin
explorer brakes are a cheap way to put disks on the back of any car or truck.
Ford Motorsports sells a whole kit for about 350 bucks...all you need is to change the housing ends to late style big ford ends, they have a larger 3.15 bearing too.
OH...you need to get some new axles made too.
THANKS AA!
1 - 8 of 8 Posts
