1 - 10 of 10 Posts
anyone ever cut up an an auto column to make a floor shift?...aka cutting out the selector and welding in a piece of sheet metal over it?
Yep. I looked for a long time for a factory floor shifty column. Guys either wanted a fortune, or I could not find one at all. I figured I would have had to "restore" it anyway, so why not just turn mine into a floor shift column?
Check out my gallery for more photos. I also shortened the housing to move the column bearing up towards the firewall more for more header clearance. It all turned out pretty nice.
I got an old one from Dustpan on here. It was in better shape than mine. I am not sure you can find new ones anywhere...
The pic above is with the bearing relocated.
Discussion Starter · #6 ·
that looks perfect!....i noticed that the housing is made out of that cheap pop metal....can it be welded? if not how did you do yours?
Discussion Starter · #7 ·
also...how did you lock the shifting mechanism to keep it from sliding down while turning?
My son and I just pulled the /6 out of his 68 Dart this weekend...so this would be a great time to do this mod to it. The car is getting a 4 speed to replace the 904 from the factory...
Smooooooooooooooooooooooooooooooooooooooooooooooooooth job!
Rick and Rickey Jr.
1 - 10 of 10 Posts
