1 - 7 of 7 Posts
After sorting out a bunch of electrical gremlins (Mostly just dirty connections) I am left with one problem I can't seem to solve. My right hand blinker acts up when the headlights are turned on. What it is doing is basically cutting power to the light instead of brightening it up when the relay clicks. So the Light is still blinking but it is off and on instead of on and then brighter. It is obviously doing it backwards of the dash light and front turn signal, when they light up brighter it goes out then when they return to normal it comes on. Other then that all the lighting works flawless now. I am thinking bad ground needs to be found, but thought I would ask some of you guys. Perhaps someone has had this problem before.
Thanks.
Discussion Starter · #6 ·
Thanks for the replies, Hoping to get sometime to work on the car before the weekend, I'll update this when I get a chance to take a look at the car.
1 - 7 of 7 Posts
