340fyd said:I'm wondering if it's a year change thing. My 64 Valiant required a draglength change. I also had a 65 Dart with a \6, but it had the dropped draglength already. Now was it changed it's life, couldn't tell you. I always wondered if it was a year change that in 65 they all came with a dropped draglength?
Lee
L6 centerlink is also dropped, but not enough. I hope IF somobody could take a picture about V8 64-65 centerlink. L6 centerlink scratces V8 oilpan... Or If someone has donor car and I could make a deal for centerlink. tnku
my64dart said:Hi,
I bought a dropped center link for my 1964 Dart. There was only a little drop in it. About a half inch or so. The 1963 thru 1966 used the same width. I bought mine from Freman's Auto in Montana for about $100.00 Try www.fremansauto.com & fill out a parts request form. It takes about 3 weeks to get a part if he has it. Make sure you tell him its for a V- 8
Good Luck
Jim
THANKS JIM!!!
What engine do You have in Your Dart? A SB I suppose? Yours information was important for me. ;D ;D
As earlier I wrote many persons had said that there's no difference, but all had smashed their oilpan... The half 1" is enough and it will not hit oilpan!!! So HELLO COULD SOMEBODY SELL A V8 centerlink 1964 - 1966 A-body![]()
mopowers said:Is the 66 drag link the same as the 65? Will a /6 66 drag link work on a BB?
All centerlinks 64 - 66 are same. As Jim wrote the only difference is the drop. If You have donor car make sure that it's originally assembled V8. You can make measurement in your L6 centerlink and hten compare it to new one. Sorry but I cant say anything about hao does it work with BB.
340fyd said:I have one that'll I'll sell for $100 plus shipping. My email is [email protected] and my phone number is 417-358-2610. It's out of a 65 V-8 cuda. I have the pan that was on the orginal 273 too, if you want that also.
Lee
Send You E-mail
my64dart said:Hi,
The center links from the 1963 thru 1966 A-Body cars are the same width. You need the drop down center link (From a V-8 car ) to put a V-8 in a car that had a slant six. I was also told to buy the #187 Mopar big block oil pan to use for the swap. The #187 has a cut out built into it for steering clearances. My motor is being built so its not installed yet. But these are the parts you need to put a big block in a early A-Body Mopar.
Hope This Helps Out
Jim
Yes It helped a lot. tnku
Jim, so you need the dropped center link for a big block also then?my64dart said:Hi,
Hope This Helps Out
Jim
