1 - 6 of 6 Posts
I need a few tips on how to pull my federal power steering pump to bits to replace the main shaft seal. I have read that the pulley is a press fit so I should be able to use a puller to take this off. Is this correct? It may become clearer once I get the pulley off as to how the rest of the pump comes apart, but any help or advise would be much appreciated.
.......Like bob says....get the proper puller.........u should not have to take it apart.........if u do make sure u have the complete kit 4 it......kim........
.....................u need to unbolt the pressure valve in the rear,being carefull to make sure nothing pops out.....and 1 or 2 bolts also on the back, havent had 1 apart 4 years.........wiggle the resesvore off the pump, may need alittle persuasion...............kim.........
Discussion Starter · #6 ·
I got the pulley off by making my own shells to grab onto with a normal gear puller. Worked sweet but took me a while. I couldn't get hold of a pulley being a Saturday today in NZ. Does the next piece unscrew?
1 - 6 of 6 Posts
