1 - 4 of 4 Posts
My turn signals quit blinking yesterday. I couldn't spend alot of time on it, but it appears there is a VERY small 3 prong flasher for the signals. It is between the ignition switch and the steering column. Is this the right one? If not, where is the correct one. Did I just not get far enuff under the dash? If this little 3 pronger is the right one, where in the hell do I find one?
On my 67's the flasher near the steering is for the emergency flashers. There is another flasher on or near the passenger sid of the radio.
Herb
You can swap the flasher's for a test. You can also try the flashers to make sure all the lights are working.
1 - 4 of 4 Posts
