1 - 7 of 7 Posts
I was wondering if the front dick brake set ups on 73-76 A bodies are all the same.For example are the 6 cylinder cars brakes the same that are on v-8 cars.And are all the bolt patterns for these years 5 on 41/2.And do the 14 inch rims come in 5 by 41/2,to fit over the brake calipers??????????
Thanks,Lance
yes.....stock S6 cars with disks have the 14" wheels. This is for the 10.87" rotor set up, commonly called 11 inch. The larger 12" (don't know the exact dim)...would require the 15 rims.
moparguru said:
is the rotors,control arms,spindels and everything the same on 6cyl and v-8 cars
Yes....they are the same parts...v8 or S6.  the torsion bar is larger in V8 cars, due to the weight.  73+ has the larger UCA ball joint that is needed for the disk brakes.  72 and earlier has the small ball joint, usually using 9" drums up front.   stock rim size is 14 with the LBP (5 on 4.5 for 73 and up). 72 and earlier uses the 5 on 4 pattern, with 13" wheels in the case of A bodies. I think 14" were optional.
1 - 7 of 7 Posts
