1 - 4 of 4 Posts
On my 68, I want to take out the inner fenders, under the hood. Is this possible? I know the top of the shock bolts to what looks like the flat panel under the hood, but I can't tell if it is bolted to that, prolly not, or a brace that is just covered up by the flat piece. I would like it to be all open under the hood cause I'm movin the battery to the trunk as well.
_-_-_
A-body's have a separate shock tower that supports both the shock and the inner fender. The inner's are spot welded to the front rad support, down along the rail and up the side of the firewall. If you pull the inner's, you should support the shock tower with a down tube, between the firewall and the frame. If you ask for a pic or do a search, you'll see the setup.
1 - 4 of 4 Posts
