1 - 3 of 3 Posts
I was contemplating cutting the inner fender out of the 66 for more room to customize a set of headers. I was just going to weld a support bar from the frame to the firwall. Can this be done? I've seen pictures, but would like to see more. Also, I supose I would have to tie in the shock support to the bar some how. What is the best way to do this? Does anyone have pictures?
I have mine cut-out with the bars welded to the firewall and front of the frame-rails. You only really need to tie the shock towers to them if you are using coil-overs that carry the weight of the car.
WOW that sounds like good news. You don't happen to have any pictures do you?
1 - 3 of 3 Posts
