1 - 4 of 4 Posts
OK i have a odd problem with my fed light harness on the Demon.
The high beams work but the low beams don't at all !!
I Already got a new Headlight switch and that checks out ok. so then i pulled the connector off th ebulk head and tested it to see if i had a good contact on my part that plugs into my bulb and that is ok.
SO now i turned the headlight switch on to send power to the headlamps, with the low beams on i'm getting about 6volts, when i pu tmy high's on i
m getting about 12volts.
I even tried replacing the Silverstar with anotehr bulb i had but it did the samething and idd not work on the low beam.
I'm at the point where i will just build a new fwd light harness unless any1 could shed some light in this darkness and i mean literally darkness.
o----o<>
I would check the dimmer switch. Ive had a couple do that. Ive never checked voltage, just replaced them. Driving down the road the low beams would flicker, or just shut off.
yeah mine does that right now! sob why did i not think of it!!! i will look into it thanks!
Discussion Starter · #4 ·
Thanks man it worked!!!! plus all my lighting is brighter in my car.
What ended up happening was teh 3 connectors that hook into the dimmer switch the little black part that they connect to melted the wires and was not giving me a good contact. I ended up breaking hte switch and then i had to bust out the wire cutters to snip away teh plastic connector just to get to teh wires. i was abel to save them and get it all back together thanks alot for the help
1 - 4 of 4 Posts
