1 - 7 of 7 Posts
OK i can't make up my mind if i should go with Autometer or Stewar Warner.
But i had a question what sending units do i need with my gauges?
I'm going all electric with mine, I'm getting the Speedo, Tach, Fuel, Water, Alt,Oil
Now my question is what would i need a sending unit on?
I went with all autometer gauges. The water temp and oil pressure gauges came with sending units and adapters. I didn't use speedo or fuel, but your stock fuel sender should work ( I can't remember the resistance values). The voltage unit just wires in, no sender required. I've always liked the autometer stuff, haven't seen the Warner ones though.
Well that sounds good i thought i was going to have to spend money on a crap load of new sending units
i like autometer. 451 is right, You order them (fuel) for a mopar and the factory sender works. Speedo cable hooks right up. Never had stewerts, but You cant go wrong with autometer
Discussion Starter · #5 ·
Well thanks guys i areally appreciate it. looks like i will end up going with autometer's and more then likely going to go with the Cobalt series
1 - 7 of 7 Posts
