1 - 7 of 7 Posts
I am getting ready to install a Wilwood adjustable proportioning valve on my Duster. Anyone have any good ideas as to where I should put it? Pictures?
Thanks,
Mark
I was wondering the same thing. I bought the SVO Corbra brake kits and a Mopar Performance adjustable valve. I don't have it all installed yet - too many projects...
I would like to get to the valve without getting under the car so that it would be easier for tuning. But as I understand it needs to mount after the distribution valve that's mounted to the inner frame rail (under the master cylinder) and it needs to go in the rear line. I haven't got to that point yet, but since I will be bending new brake lines I thought I might make a little jog in the line upward so I could mount the valve on the inner fender well. I would like to see some pictures from someone who has "been there, done that".
Thanks,
If you use the mopar/wilwood aluminum master with the plastic res.....you can mount the adj. prop. valve on the side of the garbage can. I have not used them things for about 15 years. doh and have had 0 prblems.
   On the sub frame connector with the knob through the floor under the drivers seat.
        SIKPUP ;D
i got rid of the prop. block and t-ed the front, and put mine on the frame right above the bend in the front
1 - 7 of 7 Posts
