1 - 5 of 5 Posts
There is so much info out there, I dont know what to believe, One guy says 15x10 with 7.75 B.S will fit under a stock 1970 Dart, others say 15x8 with 4.00 B.S. People are all over the place with this. My ride has a 8 3/4 rear with 10 inch drums. I know someone has done this. I cant be the alone. I just want a little meat out back without cutting my ride up. Thanks in advance.
not sure if a 69 dart is the same as a 70 duster but for me uncut no tubs with a leaf relocation kit, stock wheel wells 15 x 8 with 5 3/8 give or take +/- (5 1/4 5 1/2) back spacing depending on what's available on the type of wheel you choose will work with a 255/60/15 with a fair amount of space on both sides, one 1/4" spacer was required for that perfect look and fit on my ride.
I tried a 15 x 8 with 4 1/2 back spacing, did clear one side but no good, even if both sides cleared it would have been way to close.
good luck :)
Not to be a jerk but why don't you just measure? Measuring for rear rims is very easy.
Measure from the brake face to the leafs or tub, whichever you hit first. MEasure from the brake face to the outside. Easy peasy
Well I can tell you that my sons Dart you see here is a 72 Dart with everything stock. The springs are in stock location and it has stock wheelwells. He is running 26 x 9.5 QTP Hoosier tires on a 15 x 7 steel wheel. We tried 28's but they rubbed up front in the traps. I think the offset is 4.25 but its been years since we put them on so I will ask my son when he comes home to be sure but I think 4.25 BS is right. It has SS springs with the rest of the suspension all stock. Its a mild 400 and has run 11.40's and its a street car as it hooks fine. Ron
Discussion Starter · #5 ·
Sweet rides, looks like the Dart hooks just fine, That was the answer I was looking for, some folks say just measure, make one little mistake and own wheels that wont fit... Thanks for your input,
1 - 5 of 5 Posts
