1974 Dart swinger. Car would start if while cranking you backed off the turn of the key just a little quickly but as soon as you let the key go it would die. I replaced the key unit, the switch, the ignition box, and the coil and the car wil not start unless I run a wire from the + post on the battery to the + post on the coil. What is wrong o[
