1 - 16 of 16 Posts
My hood hinges are junk, and so is my hood. It would make my life a lot easier to buy a lift off hood (since I have only about $650 to get my 70 back on the road). Is there anyway to get a lift off on and off by oneself (since I'm usually wrenching by myself)?
Thanks
I ususally put my hands in my hemi scoop and lift! It isn't that heavy, I'm sure you could find a way w/o a scoop as well.
Drew
I wanted to buy a sixpack lift off from AAR. The scoop is strong enough? How much do the hoods usually weigh?
i would get a bolt on fiberglass hood and some hinges for $20 at the boneyard.it will be a hassle having to deal with a lift-off hood all the time.
Discussion Starter · #5 ·
I bought some hood hinges already and they weren't any better then what I had (they came off a low milage car i was told, and they look good). Problem is when I shut the hood, the hinges bow out and rub on my fenders, my 73 and 74 don't do this though, it's weird. I tried a couple of things to get the slack out of them but it didn't work. Since I'm in the middle of painting my engine bay I don't want all the new paint getting scratched off.
Discussion Starter · #8 ·
I know how the front hood pins are setup, but how did you guys do the rear?
Mine is a lift off!! I don't have a good picture of the hood pins. I have 4 pins across the front and 1 in each rear corner.
Thanks
I have a set of hood hinges in good shape(complete) if you are interested.
Mike
pin ons suck! My buddy has a pin on trunk lid for his roadchicken and he had it off while putting fuel in his cell at the gas station. Big gust of wind came along and picked the lid off the ground and flung it across the parking lot doh
Discussion Starter · #15 ·
Dumb luck prevails my friends! I got a couple of my out-of-town friends to help me bolt on my stock bent hood, and everything clears! I had disabled the springs on the stock hinges, and for some reason once they are bolted to the hood (was hard to do for some reason) all the slop comes out so that the hinges don't rub on the fenders anymore. I'm still going to get a fiberglass hood later on, it'll just be a bolt on instead.
I used to have to do it ALL THE TIME...........in High School thought it was cool to have a lift off hood car
30 years later I think it would be a pain in the A** to have to take the hood off to check the oil
The scoop was cracked where it had been lifted off and the corners were chewed up from wher they lifted it by tilting it back on the corners before I got the car
Yes it can be done, but try oiling the hinges and using a stock hood.
1 - 16 of 16 Posts
