1 - 11 of 11 Posts
the 4 bolts that hold the k-frame on a 72 dart.they are slightly larger than 1 inch and i want to buy the necessary socket to remove them, i thought they were 1 1/8" but I'm not sure.I'm trying to eliminate going to the store twice tomorrow and i'm not at the car to measure them. thanks
Discussion Starter · #2 ·
The head is 1-1/16". It's actually a 5/8" course thread bolt with an oversize 3/4" shoulder. Take care of them - they aren't made by anyone and good used ones are $20 a piece :eek:
Discussion Starter · #5 ·
Yea, I tried totally auto and r/t specialties - both told me good, used condition ones are running $20 each...
How long are they? It's been quite a while since I pulled a K-frame but aren't the welded nuts (inside the rails) open-ended, so extra length can be used? Someone must make a Gr. 5 or 8 bolt even if it's longer than needed...
Also, is there something critical about the 3/4" shoulder? Could an appropriately sized flat washer be used instead? The idea of paying $20 each for used bolts just gripes me  doh
-Charles
Premium Member
The shoulder centers the k-member. It would not be a good idea to use something else. I'm with Mark on pricing. I could go out and get 5-10 sets easy on a Saturday at the local self serve yards.
Discussion Starter · #9 ·
for that kind of $$ you oughta get a big wet kiss too!
I couldn't use my stock k bolts, I had a set of 7/8" aluminum spacers to drop the k member down to clear the headers. My stock bolts weren't long enough, so I headed to fastenal and used a nice set of socket head bolts that fit great. No problems yet.
Drew
The shoulder of the bolt serves two purposes. The above mentioned centering and it provides an area with no stress risers ("aka" threads) to make it less likely to shear in the event of a heavy impact.
1 - 11 of 11 Posts
