should a rear coil over conversion and ladder bar be used with super stock springs or by themselfs? reason i'm asking is my weight doesn't transfer as much having a big block in front and hardly no weight in the rear.
by themselves...you don't need the ss springs at all if you use the coil over conversion. 90/10 front shocks, the right coil over spring (they are rated by weight) along with the /6 torsion bars should help transfer the weight to the back of the car fine.hitmanslimo said:should a rear coil over conversion and ladder bar be used with super stock springs or by themselfs? reason i'm asking is my weight doesn't transfer as much having a big block in front and hardly no weight in the rear.
