Has anyone used these? I'm test fitting the ss springs and rear end and when I went to install the offset hanger bracket the welded nut on the hangers hits the frame. Did anyone else have this problem?. Should I cut the nut off and reweld on the other side (outboard) of the bracket? I don't want to cut a hole in the frame for the nut to sit in. It sounds dumb, but I have double checked left and right and their definitely on the proper side. If this is the way they were designed, that is stupid, seeing as there is tons of room on the outboard side for the nut. I'm guessing I'll have to cut the nut off and weld it on the outboard side and run the bolt thorugh the opposite way if a bolt with a narrow head will fit between frame and bracket. Then install springs in hangers and install all at once as an assembly. o[ **(*)
