1 - 3 of 3 Posts
Back when I was a millwright I welded with stick 7018 mostly. I have a mig that I used mainly for sheet metal repair. Recently when welding some thicker material I found that welding right to left and pointing the wire to lead the weld gave me some better results. I had always welded stick from left to right and pointed the rod back at the weld puddle (except for vertical welds). Is this something that everybody knew except me :-[
right to left...left to right...the welder doesn't care. You should lead the wire into the weld though as opposed to a drag type weld.
The angle is all a matter of the gas cup size, wire speed/amp settings and accessibility. welding vertical and overhead you'll see require some fudging around with the speed and amp settings to gain an optimal weld.
Super Moderator
uh, that would be "no".
done some very minor arc and Oxy/Acet torch stuff...even a little hammer welding, but no MIG or TIG....so its news to me.
1 - 3 of 3 Posts
