1 - 15 of 15 Posts
found out today the unit i was waiting on for months have been drop. o[ o[ o[ any one knows of a good replacement? maybe onmi, like stock looking. for 3000 lbs. car.
Re: mopar discontinue they performance master cylinder
Wilwood or Strange Engineering
Get a stock replacement Bendix unit for an 85 5th ave. I like it better then my MP unit. Plus it's only $75 brand new.
[]{}, I use a 88/89 diplomat when i shop for them, If you have the resivour (hopefully from a J/Y core), you can usually score the M/C for around $25-30 for a reman or a new one can be had for around $50---yes, parts stores sellnew ones. You work for a dealer--right? Should be able to get a deal on one through a local wholesaler.
--chad
Wilwood makes an aluminium tandem chamber MC, and it looks terrific! I have on on my car, and wilwood disc brakes on 4 corners. Really good setup for the price. I paid my MC 200$ can.
Fred
Just started browsing the wilwood site, do they make a kit for 73ish Dusters or something compatible? I was looking at piecing a 4 disc manual system together, but if I can get a kit...all the better. That MC looks a lot cleaner than a stocker.
Discussion Starter · #12 ·
i think i'am going with a unit from a 88-89 dodge diplomat.the car weight should be close .and i'll get a adjustable pro-valve for 4wheel disk.
good luck finding one from an autoparts store that is aluminum. they are all going to cast iron bodies. i guess its to easy to screw things up in the aluminum unit when they refurbish them. i could not find one local at all, new, or reman. i ordered a brand new one with resivior trough autozone and it was cast iron. me personally, i think ill pass on the reman units, especially if they are having a hard time with them.
are we talking about the late model aluminum bodied M/C with the plastic reservoir ??? Magnum HP sells them all day long. I've bought two of them in the past year, no problems with them.
1 - 15 of 15 Posts
