1 - 7 of 7 Posts
I just thought I would post the part number of the Mopar sender that I used for my electronic speedometer. It is 1-05252438. This unit is a 2 wire type and I used it with a VDO speedometer. This unit threaded right on the old 727 and gave me 8327 pulses per mile (40 tooth gear, 3.91 gear & 26.7" tires). I can help with any connection info that anyone might need.
I'm not sure what it is out of, sorry. I think any newer stuff that uses a big tranny. It will go on the 833, same speedo gear assembly as the 727.
Hello Terry,
Did you order the speedo sender from your dealer?? Oh by the way i ordered my solid lifter cam today ...no hydrralic lifters for me next season.
LOL
Maynard
Discussion Starter · #5 ·
Hi Maynard.
I just walked to the parts counter at the local dealership and asked for whatever senders they had in stock. The guy pulled this one out and I threaded it on the gear assembly, done deal. I checked it with an ohm meter and it make 8 contact closures per rev, perfect! On my speedo it switches the pulse input terminal to ground. The VDO speedo has a pull-up resistor (internal) to 12V. It works great. I had a 92 Jeep and I think this is the same sensor, 92 was long ago and my memory is not as good anymore.
I haven't gone anything with my lifters. I'm just going to drive the car a little more and then pull the motor and tranny before I store it for the winter. Full tear-down and inspect, maybe eddy heads! Winter come fast up here in Canada :(
Terry
1 - 7 of 7 Posts
