If I use a motor plate then it does not matter what k-member I use right?
R rsdart · Registered Joined Mar 6, 2006 · 8 Posts Discussion Starter • #1 • Mar 6, 2006 If I use a motor plate then it does not matter what k-member I use right?
M mope540 · Registered Joined Dec 24, 2005 · 31 Posts #2 • Mar 6, 2006 correct...and removing every bit of the motor mounts from the k-frame will make things easier to work on and look cleaner
