1 - 20 of 27 Posts
Has anyone here ever considered moving the rear axle back 2" to eliminate rubbing larger tires on the front of the wheel opening? I was thinking about doing this when I move the springs in. Does it sound like a good idea?
Mike o----o<>
Im in the process of moving mine back an inch. With 2", make sure the shock isn't at too much oof an angle.
I moved the Demon's back approx 1 1/4" with no problems at all...Shock angle is fine...
Ryan
Discussion Starter · #8 ·
Thats pretty much how I was planning on doing it, adding about a 2" spacer in there or fabbing a new box for the front of the leaf spring.
rank said:
How did you guys do this??????
Shim the front spring hanger?
My leaf springs are relocated to the frame rails, so I just had to drill a new hole for the front mount...
Ryan
I'm not sure about it, but make sure the rear shackle doesn't hit the rear frame crossmember. You may have to use longer shackles. Just a thought.
You guys that have done this, did you change/mod the shackles in any way? I was thinking about doing this to my 73 when I put an 8 3/4 in it so I don't have to cut the driveshaft (plus it'll be getting some tall rubber in there later on).
I moved my rearend back 1 1/2" , also put the springs inboard under the frame rails using te MP boxes. I also have mono leaf springs and Caltracs. The eye in the front of my spring is in the stock position , except that is moved in. The mono springs are a two peice spring , the center bolt attaches the two springs together , I had Calvert drill another hole 1 1/2 forward in the front half of the spring, this allowed me to extend the length of the front spring by 1 1/2" , therefore moving my rearend back by 1 1/2 ". Now when you drill a hole in your frame for your rear shackle you drill it 1 1/2 " back towards the rear bumper.This will keep the proper angle for your shackle. If you move back any further than 1 1/2 " I think you will be into the rear of the wheel well. I am running a 295 x 65 x 15 tire ( about 30" ) , it is very close to being centered in the wheel well.
The wheel bases on Plymouth A-bodies (Demon, Dodge Dart) are 108" and the Dodge ( Scamp) A-bodies 111", both models use the same springs. Wonder where Mother picked up three inches?
Its a 72 Valiant, and I will be using the 29x10.5 Hoosiers.
72 Valiant would have different shaped wheel openings than my 68 Dart. I made temporary spacers to move my rear axle back 5/8" to clear a Hoosier 9x30 radial slick, it measures 29-1/4" actual.
Might be best to mock this up with the stock front spring hangers and some spacers before installing your inboard spring kit.
mike.
mopardad,
I moved my springs rearward 1.75" at the same time I moved them inboard on my 1972 Plymouth Scamp. I had no adverse problems from this.
I believe any more than that you will hit the rear cross frame rail at rear bumper with your shackel.
68Valiant
68Valiant said:
mopardad,
68Valiant
68Valiant: Did you drill your hole for the rear shackle any lower or is it at the stock height?? Also, did you use stock shackles?
1 - 20 of 27 Posts
