without seeing it....make some measurements off of common benchmarks like the pop in rubber plug holes ar othe various convoluted beaded areas....then cut out and final trim and set in for a fit...use self cutting phillips pan head screws to trial fit it all into place at any overlapping areas or use clecos if you have them. Stitch it and plug weld it all into place and seam seal it up.
