1 - 6 of 6 Posts
I have a GM 1 wire alternator on my 400 big block motor and a battery cut off switch mounted at the trunk with my battery in trunk. How do I wire this switch up so that it kills the motor when turned off, I need this done to run at the track, could someone send me a wiring diagram on how to do this via fax , my fax number is 301-314-9663, also you could send a attachment via email, that adrees is [email protected]
you need to use a cut-off switch with 2 circuits(2 pole single throw type),one does the battery and the second one is the power to/from the alternator.
you will need to beef this wire up now that it has become 4 times as long going to the rear of the car.
you can use a relay to keep this wire short but vibration can cause it to invoke Murphy's law,and there is the additional parts ect.
Run the ignition power to the battery side of cut off switch ;D
1 - 6 of 6 Posts
