1 - 8 of 8 Posts
Hey! I've been trying to figure out what paint color the Barracuda was originally by looking at the fender tag, but theres several matches. So, basically I dont know which one is the actual body color. Can you guys help me?
Fender tag is as follows.
END
B5 1 G33 M21 M31 R11 V78
F8 F8 H4X X9 B18 051 600
E24 D31 BH9 B9B 21273
Yes, fender tag matches VIN.
There's B5 (Blue ;D ), X9 (Black Velvet 8) ), and F8 (Ivy Green puke; ) and I may be missing one in there... So which one is the right one? That would be sweet if it was B5... It's my favorite color! :D But I'm going to cry if it was Ivy Green Metallic. Yuck.
Oh, for what it's worth, theres a small amount of metallic blue under the purple where it's cracking. Nothing says that was the original paint, though.
Thanks guys!
Re: Need a little help guys!
Thanks for the link, but I'm still lost...
I downloaded the program and entered my #'s, and it said ''The Provided Code Information is Unknown/Undocumented for Model & Year Given''.
So... I'm positive it's the right tag and the right VIN, and I know I copied and entered the right codes. Hmmm...
I see a couple errors in your fender tag. In the bottom row, you have BH9, should be BH29, also in the bottom row you have 21273, but this should be a 6 digit number. In the second row, F8 F8 is the exterior color and the upper door/trim color (i'm pretty sure). Not positive, but I think X9 is black top. In the third row I think B5 1 should be B51 for power brakes. Hope this is some help...
Discussion Starter · #6 ·
You're absolutely right about my errors. It is BH29 and the bottom row is 212733. You're also correct about the brakes, it is B51 not B5 1. I messed these things up in translation from paper to PC. I appriciate your help very much, but now I have more problems. Could X9 mean a black painted top? The body is mostly original including the drip rails and window trim, and I see no signs of any modifications that were made to the roof, but I cant be positive of this.
In any event, it's something to look in to. Thanks again for your help.
You have yourself a green on green with black upper doors (inner part) with a black slit bench seat.
Discussion Starter · #8 ·
Thanks Ed. So the X9 is just for the upper doors? Thats cool, I had no idea...
1 - 8 of 8 Posts
