1 - 3 of 3 Posts
Anybody still use general kinetics cams? I just bought one. It has never been ran! Here are the numbers GK A5H-280-HTK! I can’t find any information anywhere!
Slip it into a block and use your degree wheel and dial indicator. You can create a cam card for it in less than an hour total, say two hours if you haven't used a degree wheel prior to today. I bought a maxed out reground 3 bolt BB cam at a swap meet years ago for $5. The guy said it was a NASCAR HEMI test cam. The lobe heels are cut all the way down into the shaft surface. Tossed it into a block and checked out the intake. 326* @ .006", .620" lift @ 1.5:1. I didn't bother to check the exhaust lobe as I didn't need an engine that idled at 1600 RPM and started making good power @ 6500:)
1 - 3 of 3 Posts
