1 - 12 of 12 Posts
I decided since my car hasnt had a heater/blower motor in it for years I would patch the holes in the fire wall up. I did this by welding the patch behind the firewall (interior side) Then welding the hole to the patch. To fil t I used a layer of fiberglass reinforced filler, sanded that down even with the firewall, then a coat of light weight evercoat and smoothed it out.
Im worried about twisting and cracking the filler when I luanch the car. Was this an OK way to do it ?
you should be fine with the way you do it .i did alot of that with my car and ive been racing it and have had no problems.. _-_-_
That looks just like the firewall I did in my Dart. I filled in everything that I could but I haven't been able to test it out yet. Sure looks good with paint on it though.
Adamr, been there done that , it is a lot of work but worth it in the end. Gives them a cleaner look.Did the same on my duster including the bulkhead and run a painless harness down low out of sight
1 - 12 of 12 Posts
