I was planning on dropping the body over the floor about 2 inches (known in the mini-truckin world as a body drop) but in order to make the body look even with the ground, I would have to drop the body crooked due to K member sitting lower than anything else. The mazda pickups that we bag have an engine crossmember that sits about 1 1/4" below the rest of the frame. Most people drag the crap out of the crossmember untill it lays flat, but some people z the frame so that the crossmember will always be intact.
My car has a slant six, I was thinking of leaving it in there and putting tripple side draft webers on it or a 4barrel Hyper-pak for that kind of different look. I havnt measured it to see how low it sits. I was planning on running dual exhuast exiting in the rear fenderwells. You wont be able to see where the pipes exit, but you will hear it. The other reason I was leaving the /6 in it was I think a 360 would be a little big with the body drop and all, I know a big block would be way to big, but you with lowriders its "low and slow" heh, I know you can get some power out of those /6. This would also give me a little room for the steering and the exhuast and stuff.I am thinking that I may have to make a larger tunnel for the tranny and driveshaft though.
I just had this Idea from seeing one of my mazda friends "Z"ing thier frame. I would love to have my Valiant laying and scraping the ground. I might have to make custom arms for the front suspension to get the amount of lift I want, I dont know, i havnt talked to the local truck group to see what they think could be done.
The car in question is not damaged at all. It is a 1971 Plymouth Valaint 4-door with a slant six. It has 80,000 original miles on it. the car is all orginal, I know it would be nice to restore it, but you can talk to anybody and they will tell you that when restoring a 4-door, you will spend more money than the car is worth. I am kind of on the verge to sell it or start customizing it. I have never seen a bagged and bodydroped mopar before, nor one that lays the subframes.
Thanks Bill for the info, you gave me some more things to think about an measure. do you think a 360 is any bigger in the engine bay than a slant six, if it would fit nicely with it laying, I might be able to use a stripped down version of the alter-k with the double A-arms which would be way easier. Does the alter-k sit the same distance beloe the rails or is it tighter?
thanks again
-Mike
