Can they make some power if you want to wrestle with them? Yes. They just are an early, crude cylinder head design. They need a tremendous amount of work to flow good. Short valves and large 3/8" diameter valve stems. Odd outside diameter brass valve guide. The spring pockets will fill up with oil above the valve stem seal if you don't do some special machining to get them to drain. Special intake gaskets and valley pans. 440 intakes or 3/4" spacer plates with 383/400 intakes on 383/400 engines and 3/4" spacer plates for 440 intakes on 440 engines. Not worth the hassle to me.
Hi,I am a new member and long long time mopar fan,my first post here.
which heads are you mentioning here?
I see that you had experience w/teh ebay.com/itm/Mopar-Chrysler-BB-383-440-325cc-78cc-CNC-Hydr-R-Complete-Aluminum-Cylinder-Heads-/201627129491?hash=item2ef1e9d693:g:KnwAAOSwqfNXjblT&vxp=mtr&rmvSB=true
I just received a set of these:
speedmaster79.com/au/pce2812140-mopar-chrysler-bb-383-440-265cc-74cc-hydr-ft-complete-aluminum-cylinder-heads/
any 'heads-up' to look out for would be nice,I am going to change out the springs also I noticed the intake valve are longer...
this is a mild build and really wanted to lighten the load
thanks
